Question about intakes...
Ok, can someone please give a DETAILED description of what an intake does? Also, why is the stock one not good? How do the different top brands of intake differ from one another?
Startin' to learn about mods... any help is appreciated.
intake sucks in air to be directed into the manifold where it goes in to be combined with fuel so ur car can combust the **** and get power from it
The only different an aftermarket intake is from your stock box is that it'll suck more air in, but you should get a cold air intake cause they'll suck cooler air in, with the regular intakes, they mostly suck in the heat from your motor.
Seriously dude.. you've made a few posts that have been answered, but use the search function!
And a little common sense goes a long way: "What does an air intake do?" Air. Intake.
Welcome!
Welcome!
Welcome!
Welcome!
Air intake, huh? Common sense does not say why the stock intakes are not as good as aftermarket intakes. And common sense does not explain that cold air is needed because it's more dense with oxygen molecules which accelerate combustion in order to give more power. I did say that I wanted a DETAILED description. You must understand this is not common sense.
Don't just write something for the sake of getting noticed. And thanks for welcoming me aboard. I felt all warm inside. Really. Cheers.
I would just like to welocme another fellow Montrealer to the board!
If you every need any help installing something, just let em know.
Not that I'm any good mind you...
Ohlias
Ohlias
deerman2701
Apr 30, 2008 04:33 PM
92c1v1cHATCH
14
Sep 13, 2006 08:29 AM
