Sway Bar
Old Sep 1, 2003 | 10:32 AM
fucT's Avatar
Default Sway Bar
Whats a good sway bar to go with. Not looking for something to expensive, its a daily driver and every once in a while I will be taking it too the track, so i want it to be reliable quality but not something for a complete race car. Ive read up on some of them and they are usually rear only or the front one is stock diameter. Can some one explain that for me? Much help would be appreciated. Thank you.
Old Sep 1, 2003 | 10:34 AM
itr1235's Avatar
Default Re: Sway Bar (fucT)
what car
Old Sep 1, 2003 | 10:38 AM
fucT's Avatar
Default Re: Sway Bar (itr1235)
sorry 99 civic ex
Old Sep 1, 2003 | 10:44 AM
fucT's Avatar
bump
Old Sep 1, 2003 | 10:47 AM
tominos's Avatar
itr 22mm rear sway w/ beaks reinforcement kit
Old Sep 1, 2003 | 10:49 AM
fucT's Avatar
Default Re: Sway Bar (tominos)
why only rear?
Old Sep 1, 2003 | 12:36 PM
fucT's Avatar
Old Sep 5, 2003 | 05:43 AM
SOHC_MShue's Avatar
your stock front sway bar should work fine. Just get the rear.
Old Sep 5, 2003 | 05:52 AM
JDMCRX's Avatar
Default Re: Sway Bar (SOHC_MShue)
Supositely the EX front bar is like 24mm with no rear. The SI is 26mm but u have to change ur lower control arms or use the SI bar with ITR end links. caus the SI uses a Ball joint type end link with a bushing bottom.
Old Sep 5, 2003 | 06:47 AM
RickChew's Avatar
Default Re: Sway Bar (JDMCRX)
Keep your stock front sway bar, making it larger will only make your car handle worse (more understeer) Get a 99-00 SI rear swaybar if you can find one, they usually go for pretty cheap (around $60). That will be fine for the street. The 22mm is a little extreme for the street, causing your rear end to swing out if you turn hard. You can run if you would like, but just be safe in the corners! Rick
amej8
Jun 17, 2008 06:16 AM
Rouin
Honda Civic (2006 - 2015)
Mar 11, 2007 12:51 PM
stuie08
Nov 25, 2006 02:30 PM
turnsignalandy
May 28, 2006 09:14 PM
EK-Cruiser
Aug 24, 2001 02:57 PM
