Is This What a Bad Ignition Rotor Look Like?
Old Sep 1, 2003 | 09:37 AM
CPR's Avatar
CPR
Default Is This What a Bad Ignition Rotor Looks Like?
I replaced the rotor at 30,000miles and I'm now at 48,000.
a.) Is this normal wear on a rotor w/18,000 miles on it and does it look like it needs to be replaced?
b.) What can cause abnormal wear on the ignition rotor? Advanced timing maybe???
c.) How often should I replace spark plug wires? I inspected the terminals and they look ok.
Old Sep 1, 2003 | 09:45 AM
oryanh's Avatar
Default Re: Is This What a Bad Ignition Rotor Looks Like? (CPR)
A side view may help... since wear would change the shape of the contact.
I started to change mine last night, and it looked exactly the same @29k miles. So i just hit it with #600 sandpaper till it was all silver, like the lower-end of your pic. I ended up only replacing the cap.
Your plugwires are probably fine, but they're moslty effected by heat. You live in a hot climate?
Old Sep 1, 2003 | 10:02 AM
Bbasso's Avatar
get a side veiw and a pic of the inside of the cap too.
Old Sep 1, 2003 | 10:03 AM
Smitdog's Avatar
Default Re: Is This What a Bad Ignition Rotor Looks Like? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">get a side veiw and a pic of the inside of the cap too.
Old Sep 1, 2003 | 11:49 AM
CPR's Avatar
CPR
Default Re: Is This What a Bad Ignition Rotor Looks Like? (Smitdog)
Old Sep 1, 2003 | 12:09 PM
Bbasso's Avatar
You need a new cap and rotor.
Old Sep 1, 2003 | 12:26 PM
CPR's Avatar
CPR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">You need a new cap and rotor.</TD></TR></TABLE>
I can see how I can need a new rotor but what did you see to also suggest that I needed a new cap?
Old Sep 1, 2003 | 12:36 PM
Bbasso's Avatar
The contacts inside the cap look like they have worn down just enough to warrent the need for a new one, and since they are not alot of money Ya do it.
Old Sep 1, 2003 | 03:11 PM
canuckr's Avatar
What the others above said, you need a new cap and rotor.
Also remember to tighten the screw on the rotor!! The screw came out in mine and killed my distributor
Old Sep 1, 2003 | 03:43 PM
CPR's Avatar
CPR
Default Re: Is This What a Bad Ignition Rotor Looks Like? (canuckr)
I've only had the cap and rotor for 18,000miles. Is it normal for them to wear out so fast? What contributes to accelerated wear on these parts?
Old Sep 1, 2003 | 11:06 PM
mingchi69's Avatar
I to Smooch Pickle
high revs..
Old Sep 2, 2003 | 07:57 PM
WTypeRogerX's Avatar
My CRX si rotor lasted 90k, but I didn't race it or rev it hard too often.
Old Sep 2, 2003 | 11:12 PM
cxSHOE's Avatar
Default Re: Is This What a Bad Ignition Rotor Looks Like? (WTypeRogerX)
is it just me or is taking that damn rotor out such a bitch??? what would everyone suggest, yes the screw was off the rotor... ive pulled and pulled, and still nothing..
thanks
Old Sep 5, 2003 | 05:06 AM
oryanh's Avatar
Default Re: Is This What a Bad Ignition Rotor Looks Like? (88hf)
Get a bit that fits, and a screwdriver that has a beefy handle.
Old Sep 5, 2003 | 09:08 AM
Spirit Iron knife's Avatar
Default Re: Is This What a Bad Ignition Rotor Looks Like? (oryanh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oryanh &raquo;</TD></TR><TR><TD CLASS="quote">Get a bit that fits, and a screwdriver that has a beefy handle. </TD></TR></TABLE>
Why? The screw is already off the rotor.
You just have to wiggle it until it comes off, sometimes they're stubborn. I used a flathead on the inside edge of it to try and free it, while I pulled on the rotor, eventually it came out. It was a pain in a@@
Old Sep 5, 2003 | 11:27 AM
t616
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88hf &raquo;</TD></TR><TR><TD CLASS="quote">is it just me or is taking that damn rotor out such a bitch??? what would everyone suggest, yes the screw was off the rotor... ive pulled and pulled, and still nothing..
thanks</TD></TR></TABLE>
just pull of your dizzy, its so much easier to work with.
Old Sep 5, 2003 | 11:39 AM
B18CXr's Avatar
I replace them every 20 or 30K no matter what driving conditions....
Old Sep 5, 2003 | 05:29 PM
cxSHOE's Avatar
Default Re: Is This What a Bad Ignition Rotor Looks Like? (Cult of Staxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cult of Staxx &raquo;</TD></TR><TR><TD CLASS="quote">You just have to wiggle it until it comes off, sometimes they're stubborn. I used a flathead on the inside edge of it to try and free it, while I pulled on the rotor, eventually it came out. It was a pain in a@@</TD></TR></TABLE>
yea it was a bitch, but finally, after two fucken days the **** finally came off, piece of **** part, i put a dab of grease on the tip, hopefully that will help the next time i have to change it...
Lb1atx
Jul 18, 2007 04:29 PM
oblique
Nov 25, 2004 11:27 PM
ApexiChild
Mar 18, 2004 06:40 AM
Bspec18
Aug 1, 2003 09:56 PM
HavokB18
17
Apr 21, 2003 03:44 PM
