check engine (code 7) plz help asap
Old Aug 31, 2003 | 07:52 PM
TURBODC4TEG's Avatar
Default check engine (code 7) plz help asap
btw i have searched and not had any luck with this. i have a 97 ls w/ a obd 2-1 jumper running a 92 ls ecu. my kit is a rev hard stage 2c. Here is the problem sometimes the check engine light comes on and i check the code its a 7 which is tps. when i take out the ecu fuse and the unhook the tps sensor for a few secs it will sometime clear up the problem. could my tps sensor really be going bad? anyone else had this problem with a turbo ls? it never use to do this but now its been doing it alot plz help. thanks
Old Aug 31, 2003 | 08:20 PM
Default Re: check engine (code 7) plz help asap (turbolsteg)
bump
DB1_559
Mar 27, 2008 08:57 PM
REDREXMANB16
Nov 23, 2006 09:54 PM
kaoss_11
Sep 10, 2006 04:14 PM
9WON4
Apr 22, 2004 05:38 PM
ransack
Apr 7, 2004 03:57 PM
