Fuel pressure and regulator question (i searched)
Old Aug 31, 2003 | 04:16 PM
slooogsr's Avatar
Default Fuel pressure and regulator question (i searched)
im tryin to get my fuel pressure set correctly but i have a few questions but first my setup
dohc zc with a b&m fpr and gauge..........
first question: what do you go by to set ur pressure, is it at idle or when you crack the throttle?............. the reason why i ask is because when i crack my throttle my pressure gauge needle jumps up 5-6lbs.......... is my fpr not working properly or should i just install a factory unit? if so which one should i use for my zc......... thanx guys............. also what pressure should i be at?
Old Aug 31, 2003 | 04:59 PM
Patch's Avatar
Default Re: Fuel pressure and regulator question (sloorex)
The spec is 35-42 psi at idle with the vacuum hose disconnected.
Old Aug 31, 2003 | 05:25 PM
slooogsr's Avatar
wow......... my pressure must be waayy off then........ thanx
Old Aug 31, 2003 | 07:53 PM
slooogsr's Avatar
set it back to around 35-36 with the hose off and it had a rough idle and would hesitate on acceleration.......... any other ideas?
Old Sep 1, 2003 | 04:21 AM
Patch's Avatar
Default Re: (sloorex)
Any codes?
Old Sep 1, 2003 | 06:06 AM
silverCRXTC's Avatar
Default Re: (CRX PAT)
u set it and then put the hose on and check the pressure, i did mine and i got it to 42 psi but with the hose off it shoots up to like 60, just **** with it and ull get it eventually
Salami
Dec 24, 2011 08:07 AM
hybrid98
Aug 15, 2007 12:54 PM
crxtreme27
Feb 4, 2003 08:28 PM
crxtreme27
Feb 2, 2003 11:02 PM
Grandprix
Dec 6, 2001 02:36 PM
