HELP Horrible Exhaust Rattle
Old Aug 31, 2003 | 03:52 PM
ScottFern's Avatar
Default HELP Horrible Exhaust Rattle
I recently got my car running with my b18c1 swap. I have an APEXi DUNK exhaust setup, JDM ITR 4-1 header, with a carsound custom cat, and we bought some bolts and nuts from home depot and bolted it up, we didn't use any spring loaded bolts though.
Whenever the motor is at certain RPMs the exhaust hits spots on the underbody of my hatch, anyway I can get this to stop ? ITR exhaust bolts ?? Also, the muffler starts hitting the rear bumper too and causing big noises.........
Old Aug 31, 2003 | 04:24 PM
ScottFern's Avatar
Default Re: HELP Horrible Exhaust Rattle (ScottFern)
anyone ?
Old Sep 1, 2003 | 10:38 PM
ScottFern's Avatar
anyone ?
Old Sep 1, 2003 | 10:49 PM
mmuller's Avatar
Mad Scientist
what is it, too high, to one side, to loose??
getting the spring loaded would obviously help
Old Sep 4, 2003 | 01:34 PM
ScottFern's Avatar
Default Re: HELP Horrible Exhaust Rattle (mmuller)
what spring loaded bolts should I buy ITR ones ?? I need something, the rattle comes mainly from my rear passenger side, where the pipe bends to go back toward the muffler......
I think I have the bolts on the cat so tight, that it shakes the whole exhaust system ?? Would bolts fix this, or do I need to do more ?
Old Sep 4, 2003 | 04:44 PM
ScottFern's Avatar
any info ?
Old Sep 4, 2003 | 05:03 PM
Jaesung's Avatar
b-quiet.com
Old Sep 4, 2003 | 06:56 PM
Turbo12acer's Avatar
I would have to say get a spring bolt kit. See if any progress. If still rattling, check rubber on hangers to make sure there not all worn out. After that, try to get the car lifted and hit the exhaust from the header to muffler, if you hear rattling youll know where it is comming from. Hope this helps
Old Sep 4, 2003 | 07:22 PM
PHiZ's Avatar
Default Re: (Turbo12acer)
also check to see if it's your O2 sensor hitting your new/different shift linkages...
-PHiZ
Old Sep 4, 2003 | 07:25 PM
animated_life's Avatar
mine does the same thing with my evo on my teg. i replaced the rear rubber hangers and it stopped the noise for a while...but then it came back. happens mostly when the AC is on. since i have the spring loaded bolts, and it still happens to me, i kind of doubt that you buying some for your car would help your problem...but it might help a little.
Old Sep 4, 2003 | 08:51 PM
MrTodd's Avatar
Default Re: (animated_life)
All of the above ideas are excellent places to check. Make sure you know EXACTLY where the sound is coming from, you WILL have to get underneath the car while the motor is running, and have a 2nd person play with the gas pedal a little bit to hear the noise. Sometimes banging on the exhaust piping can make the rattle as well.
I have one more thing to add on the list: The catylytic converter itself. The honeycomb material inside could be rattling. It happened for the 2nd time with my CatCo cat. I ended up gutting it. Piece of crap... Heh, actually it turns out I was running a little too rich, and since catco sucks at making bolt-in cats, the honeycomb fell apart.
Simply remove the cat, and look inside. If it's screwed, you'll see it. Good Luck!
Old Sep 4, 2003 | 09:42 PM
MEANB18's Avatar
Default Re: (MrTodd)
hey if you are using different shift linkage, you might have dropped one of the bolts onto the heat shield running above the exhaust all the way back... Iknow my friend did this, and it took a while to get it out!
Old Sep 4, 2003 | 09:43 PM
Session101's Avatar
Check the tightness of the bolts and the condition of the rubber hangers. But MrTodd could be correct about the CatCo cat as I have had numerous friends who had problems with them. Good luck.
Old Sep 5, 2003 | 11:04 AM
ScottFern's Avatar
Would anyone know where I could pick up a spring loaded bolt setup for my exhaust ???
Old Sep 6, 2003 | 05:29 PM
yeah, goto a auto parts store and ask them for a spring bolt kit for y oru honda. thell get it for you.
Old Sep 6, 2003 | 05:43 PM
ScottFern's Avatar
Default Re: HELP Horrible Exhaust Rattle (Turbo12acer)
Pep Boys actually stocks that stuff ??? haha, <---stupid qustion
jdmark1
May 7, 2017 02:53 PM
jkalex05
Aug 8, 2009 02:09 PM
FOrSfEd
Apr 10, 2005 05:35 AM
94AccordCoupe
18
Feb 12, 2004 11:36 AM
SupaTegRS
May 8, 2003 05:33 PM
