distributor???
Old Aug 31, 2003 | 03:19 PM
ic0n's Avatar
Default distributor???
how can you tell if its a gsr distributor, is there a code some sort of number that you can tell its a gsr distributor
thanx
Old Sep 5, 2003 | 03:17 AM
mattb16a1civic's Avatar
buy a new one if its the same return the new one if its not then keep the new one. other than that im not sure if there is actually a pt number on the cap., im looking at a brand new cap from honda and there isnt a pt number on it.
Old Sep 5, 2003 | 05:22 AM
JDMCRX's Avatar
Default Re: distributor??? (ic0n)
well first of all does it bolt on??? if it bolts on the B series VTEC head all 3 bolts then its a B series DIS. But if the botom bolt does not its a Non vtec. Also the connector on it is one connector OBD0 is 2 connectors
ferio-ichi3
17
Nov 5, 2015 12:11 PM
markviiisvt4
Oct 17, 2007 08:08 AM
d15b7racer
Jan 7, 2005 04:26 PM
psi on u
May 17, 2004 09:31 PM
