good manifold and TB for race motor
Old Aug 31, 2003 | 12:03 PM
dumbshit's Avatar
Default good manifold and TB for race motor
I was considering using the jg manifold but have been told I will loose alot of power becuase its to large, is this true or not? and I was considering going with a 75mm TB should that be OK?
thanks
85mm, 14:1,nasty cams and more headwork than peter north
Old Aug 31, 2003 | 04:49 PM
ranta18's Avatar
Default Re: good manifold and TB for race motor (dumbshit)
skunk2 or moddified factory manifold and str 70mm tb should do it.
Old Aug 31, 2003 | 04:57 PM
jdmcx's Avatar
Default Re: good manifold and TB for race motor (ranta18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 or moddified factory manifold and str 70mm tb should do it.</TD></TR></TABLE>
Old Aug 31, 2003 | 08:40 PM
NA gs-R 05 C
Guest
Posts: n/a
port match b16/itr intake manifold, skunk 2 or if you want to be crazy ... ITB's, but the port match b16/itr or skunk 2 is good enough, and a 70mm TB is also good if you're going to go with the b16/itr or skunk 2 IM.
Old Aug 31, 2003 | 09:38 PM
96dxB16's Avatar
if you're going all out get some toda itb's and motec to run it all
Old Sep 1, 2003 | 06:24 AM
dumbshit's Avatar
Default Re: good manifold and TB for race motor (96dxB16)
ITBs are way over rated, I do know that holland uses the jg piece and thats kind of what turned me on to it.
Old Sep 1, 2003 | 01:27 PM
AussieK24's Avatar
ITR TB and IM
Old Sep 1, 2003 | 03:20 PM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumbshit &raquo;</TD></TR><TR><TD CLASS="quote">ITBs are way over rated</TD></TR></TABLE>
They sure are.
Old Sep 1, 2003 | 03:42 PM
dumbshit's Avatar
Default Re: good manifold and TB for race motor (AussieB20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AussieB20vtec &raquo;</TD></TR><TR><TD CLASS="quote">ITR TB and IM</TD></TR></TABLE>
Ha ha. This head flows a bit better than that.
Old Sep 1, 2003 | 03:48 PM
MAX_CFM's Avatar
JG will make good power if ya have a great engine
Old Sep 2, 2003 | 04:41 AM
AussieK24's Avatar
Ha ha. This head flows a bit better than that.</TD></TR></TABLE>
Old Sep 2, 2003 | 05:34 AM
MAX_CFM's Avatar
What size valves......
Old Sep 2, 2003 | 05:48 AM
Suprdave's Avatar
Default Re: good manifold and TB for race motor (MAX_CFM)
A Ported ITR Manifold and 62-65mm (plate) Throttle Body can support any power you can reasonably make.
Suprdave
Old Sep 2, 2003 | 06:28 AM
AussieK24's Avatar
Default Re: good manifold and TB for race motor (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">A Ported ITR Manifold and 62-65mm (plate) Throttle Body can support any power you can reasonably make.
Suprdave</TD></TR></TABLE>
That's what I'm talking about. People are making 280whp with ITR IM's
DRAG_WORKX
Apr 4, 2007 04:10 PM
whitehf
Jun 27, 2006 01:50 PM
boostedcivicsir
Oct 28, 2004 03:39 PM
AGPSuperstar
Feb 10, 2003 08:44 AM
DynamiteSJ
Oct 12, 2002 10:20 PM
