White spark plug on cyl 1??
Took the spark plugs out today, I found them all brown except the cyl 1 plug appear white.
It may running lean or overheat but what cause the problem, my friend told me it may be the injectors clogged.
any suggestion. thanks
yes white is generalyl lean, id also suggest cleanign the injector, you should talk to someone at a dealership about injector cleaning nto the stuff u buy in a bottle but stuff they actually feed into your fuel rail, its pimp **** used it at UTI. we just used gm cleaner for everything even in the imports, called honda and they said it was fine.
