Tranny won't shift!!!
Old Aug 31, 2003 | 03:05 AM
xSpooNxEkx's Avatar
Default Tranny won't shift!!!
i barly installed a jackson racing supercharger and now the gears won't go into 1st 3rd and 5th this is for a type-s woundering if any of you can help me out... also if anyone have any experienced with this supercharger please let me know because it isn't keeping idle and the car rev's from 1 grand to 2 grand all the time.... not the iac problem and when you shift from 2nd to 4th the rpm jumps up to 5k... thanks
Old Aug 31, 2003 | 01:17 PM
CHILIBEANZ's Avatar
this might be a long shot but have u checked the clearance between the intake and the tranny lever. i had to move mine about an inch forward so it would clear. then put the car in fifth since that's the furthest one out and check clearance.
Old Aug 31, 2003 | 02:08 PM
eg_nezay's Avatar
Default Re: Tranny won't shift!!! (xSpooNxEkx)
Sounds like you need a new clutch, thats a common problem when you go FI.
About the idle, sounds like you have a leak somewhere,the hard part is, finding where.
Good luck.
Old Aug 31, 2003 | 09:25 PM
xSpooNxEkx's Avatar
Default Re: Tranny won't shift!!! (eg_nezay)
i barly put the supercharger in the car so the clutch can't be messed up... but do you have any pix on the tranny clearance because i don't really know wut your talking about... i might have a clue but imma just make sure thanks
Old Sep 1, 2003 | 03:59 PM
CHILIBEANZ's Avatar
i don't have an intake on my car anymore (turbo now) but when i did have it, the shift linkage wasn't clearing the intake piping so i had to move it forward a bit. u should be able to find pix on clubrsx. loosen the bracket holding the intake on to the throttle body then pull the piping forward. it should leave barely an inch when the car is in 5th gear. then tighten it back up and you're good to go.
Old Sep 2, 2003 | 05:39 PM
xSpooNxEkx's Avatar
Default Re: (p220)
thanks alot i solved the situation with the shifting gear
Old Sep 3, 2003 | 05:24 AM
snipersi's Avatar
if you still have the idle problem; make sure your spark plugs are tight and firing.
Old Sep 3, 2003 | 10:16 AM
CHILIBEANZ's Avatar
Default Re: (xSpooNxEkx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xSpooNxEkx &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot i solved the situation with the shifting gear </TD></TR></TABLE>
no problem. so it was the intake right?
Old Sep 3, 2003 | 11:17 AM
allmtrSI's Avatar
so how's it feel now that you're supercharged? pretty good i bet..
Ge-money
18
Nov 18, 2006 05:43 PM
Kyles ej1
Jun 30, 2004 04:42 PM
KiDSoL
Jun 7, 2003 02:27 AM
MisterHYBRID
Oct 27, 2002 04:48 AM
OldSchoolCrxSiR
11
Jun 23, 2002 04:16 PM
