LS/VTEC? on timing belt and head gasket .
If you are using the GSR/ITR oil pump you'll use the GSR/ITR timing belt. If it's the LS oil pump, you can use your stock timing belt (though it's a great time to replace it.) Use a headgasket from the LS.
Let me know if you run into any other problems MadPJ7@netscape.net
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadPJ7 »</TD></TR><TR><TD CLASS="quote">If you are using the GSR/ITR oil pump you'll use the GSR/ITR timing belt. If it's the LS oil pump, you can use your stock timing belt (though it's a great time to replace it.) Use a headgasket from the LS.
Let me know if you run into any other problems MadPJ7@netscape.net</TD></TR></TABLE>
No, if you use a vtec WATER pump=vtec t-belt , non/vtec pump=non vtec belt
wade
Jun 20, 2004 02:21 PM
