white ash on exhaust valves? wtf
Old Aug 29, 2003 | 06:23 PM
Quetzolcotl's Avatar
Default white ash on exhaust valves? wtf
bought a used head. it looks alright but instead of black carbon deposits on the exhaust valves there is a white looking ash. also the combustion chamber looks more oily than it should. could it have been abused with N2O before or anything?
Old Aug 30, 2003 | 07:16 AM
D-Man's Avatar
Default Re: white ash on exhaust valves? wtf (Quetzolcotl)
that's normal,it was burning alittle oil thats all.
Old Aug 30, 2003 | 08:12 AM
Muckman's Avatar
Moderator in Chief
I bought a used head. It absolutely sucked. Had so much carbon on the valves that they did not seal. Had to have a machine shop do a valve job to grind all the seats.
After you put the head on and torque down the head bolts, before you put the cams on so all the valves are shut - compress some air into the cyclinders (leakdown) to make sure everything is sealing right. No sense putting it all back together to realize u have a few valves not sealing....
Old Aug 30, 2003 | 09:30 AM
blackeg's Avatar
Default Re: white ash on exhaust valves? wtf (Muckman)
i also just bought a used head and the exhaust valves are white, which i assumed was from running hot. it kinda didnt make sense tho, cause the spark plugs were showing normal wear/operating temperatures. im taking my valves out and im gonna have it tanked to get all the deposits off before i put it on.
Old Aug 30, 2003 | 09:59 AM
PAPOBMX's Avatar
Default Re: white ash on exhaust valves? wtf (blackeg)
dude return the head to the kid cuz the ***** was running a lot of nos on the engine or if you keep it make sure you send it to the machine shop for port and polish and buy a brand new set of valve train kid
eg:R
May 24, 2009 12:54 PM
92ehatch
21
Nov 13, 2007 01:58 AM
tuan...
Sep 7, 2004 04:27 PM
KooK
May 22, 2003 07:23 AM
JDM_ITR
Jul 17, 2002 05:25 AM
