White corrosion on exhaust valves
anyone know what can cause this? leaking coolant to cylinders or lean?? will seafoam clean this?
Re: White corrosion on exhaust valves
was the car smoking when it ran?
I rebuilt a d16 head that had burnt white matter on the valves in one cylinder that I could scratch off with steel wool. after removing them I found oil built up behind them. I'm sure it's the same.. bad valve seals
yes the car is smoking. cylinder 1 seem to have oil on the piston. all exhaust valves in all cylinder are white. what causes this white corrosion to the exhaust valves
just pull the head it takes u less than an hour..........................................
a manchine shop can tell it all...
92ehatch
21
11-13-2007 01:58 AM
