HELP!
I tried to do my own timing belt job and there was an emergency so I had to put everything back on. To save time, I just put the bottom tb cover on without the front or the back tb covers. I started up and it sounded fine until I went to the engine bay. It souded different. More like a squeal. It is not very noticable though.
Is this a problem or it is just because I don't have my top tb covers thus it sounds different? I did remove the adjuster bolt and turned the engine about 2 times and then tighten the bolt back up. Is it possible to overtighten the tb with auto tensioner? When the tb is really tight, is the squeal loud or subitle?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda »</TD></TR><TR><TD CLASS="quote">the squeel is probally a drive belt not a timing belt because the timing belt has teeth so it doesent slip</TD></TR></TABLE>
It could be a bad bearing also. (Water pump, tensioner.)
marymiller29456
Classic Hondas
Oct 31, 2012 12:03 PM
