a/c condenser r and r
I am looking for tips and instructions on how to remove and replace
the A/C condenser on my 1993 Accord EX 2dr... The previous condenser
was damaged by a rock and I intend to replace it and then recharge the system...
Thanks in advance...
sweating in TX..
Mark Williams
sweating in TX..
Mark Williams
I'll be in dallas this Sunday if you need help. It's a pain if you don't have the right tools to make it easy. You have to get the belt, then the lines off, then you can loosen the 4 12mm bolts that hold it on. This would be a good time to convert to r134.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by judonoh »</TD></TR><TR><TD CLASS="quote">I'll be in dallas this Sunday if you need help. It's a pain if you don't have the right tools to make it easy. You have to get the belt, then the lines off, then you can loosen the 4 12mm bolts that hold it on. This would be a good time to convert to r134.</TD></TR></TABLE>
You don't need to do anything with the belt for replacing the condenser.... just remove the little crossmember or shroud over the top of the radiator area, remove any mounting bolts for the condenser (mine has 2 10mm), disconnect the 2 lines and it should slide right out the top
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89_LXi »</TD></TR><TR><TD CLASS="quote">
You don't need to do anything with the belt for replacing the condenser.... just remove the little crossmember or shroud over the top of the radiator area, remove any mounting bolts for the condenser (mine has 2 10mm), disconnect the 2 lines and it should slide right out the top</TD></TR></TABLE>
he is right once you disconect the ac hoses it should come out pretty easy .... remember to remove any pressure from the system if you have any freon left in there
and dont waste your time converting to r134a just use Freeze 12 it is a great replacement to R12 and it is pretty cheap too....
kai-chun
Sep 5, 2006 01:09 PM
bmw626
Sep 9, 2005 04:45 AM
Tom Civic
Nov 20, 2004 03:08 AM
