Car not driving straight...
Old Aug 28, 2003 | 08:25 PM
Mag00n's Avatar
Default Car not driving straight...
I got into an accident about a month ago, front end. I finally have her back together and I've noticed that whenever I let go of the steering wheel, the car pulls toward the right, pretty hard IMO. I kinda have to hold the wheel slightly to the left to keep it straight. My first thoughts were to check the alignment, I find that the drivers side is way off, so I have it fixed. It's still doing it. Does anyone have any ideas on what else I should check? I'm praying I don't have frame damage. Impact was about 7-10mph, not a bad accident at all. Anyways thanks for the help.
Ryan
Old Aug 28, 2003 | 08:35 PM
feelthebreak's Avatar
have the alignment checked again.
does the steering wheel sit normal like it used to? or is it off when you`re going straight?
Old Aug 29, 2003 | 08:52 AM
Mag00n's Avatar
Default Re: (feelthebreak)
hmm, tough to say, I think it feels a little off....
Old Aug 29, 2003 | 09:10 AM
Foozball26's Avatar
Default Re: (sickSOLvtec)
alignment can still be off even if the wheel is straight.
just go get an alignment, not a hard problem to solve.
Old Aug 29, 2003 | 09:26 AM
Mag00n's Avatar
Default Re: (Foozball26)
well, the problem is that I just got one a few days ago and the problem persists, I guess I should take it back and make them check it again?
Old Aug 29, 2003 | 09:39 AM
tpr's Avatar
tpr
It may be a seperated belt in the tire. Switch the front tires side to side. If it pullls the other direction then its deffinately the tire.
Old Aug 29, 2003 | 09:48 AM
Foozball26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickSOLvtec &raquo;</TD></TR><TR><TD CLASS="quote">well, the problem is that I just got one a few days ago and the problem persists, I guess I should take it back and make them check it again?</TD></TR></TABLE>
you might wanna take it back, just to make sure.
Also get them to check the tires like stated above.
And look up under the car while its on the alignment machine to see if anything suspension wise looks odd.
Old Aug 29, 2003 | 12:39 PM
Aceman64's Avatar
Default Re: (tpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpr &raquo;</TD></TR><TR><TD CLASS="quote">It may be a seperated belt in the tire. Switch the front tires side to side. If it pullls the other direction then its deffinately the tire.</TD></TR></TABLE>
I was going to say the same thing. Both me and a friend have the same problem, but if you switch the tires it pulls the other way.
-Ace
Old Aug 29, 2003 | 12:54 PM
HiroHatch's Avatar
Default Re: (Aceman64)
got to westend
pbizzlegsr
Mar 7, 2007 06:19 PM
Dwight Schrute
Suspension & Brakes
Oct 1, 2006 05:58 AM
BlackGS01
Jan 18, 2005 01:00 AM
dyases
Jun 10, 2004 08:56 PM
