Used MSD BTM unit for sale!
Old Aug 28, 2003 | 07:22 PM
djmatix's Avatar
Default Used MSD BTM unit for sale!
I've got a used MSD BTM unit that I no longer need. My fuel management retards the timing for me. This is a great tool to have if you guys are using the v-afc hack. Boosting 10psi and having 42 degrees timing advance is BAAAAAAAAAAAD. Use this and you can bump it down to a safe level for boosting. 125 dollars and its shipped via UPS to your door w/ tracking number. The shop I work for is an authorized UPS shipper and you will get your tracking number immediatly upon payment.
full instructions on installation can be found here. (hosted on my webspace so you can view it if you buy it.
http://www.m2-motion.com/MSD-BTM.pdf
If you run a blower or turbo, MSD's Boost Timing Master can prevent detonation by automatically retarding the timing as your boost pressure increases. The secret lies in a boost pressure sensor that's inside MSD's solid state control box. The sensor reads boost pressure through a 1/8 in. vacuum hose attached to a boost pressure source. The result gives you peak power without harmful detonation. A dash-mounted control **** allows you to dial in the retard from 1 to 3 degrees per pound of boost pressure to a maximum retard of 20 degrees.
Modified by djmatix at 4:32 AM 8/29/2003
Old Aug 28, 2003 | 07:32 PM
djmatix's Avatar
bump
Old Aug 29, 2003 | 05:11 AM
djmatix's Avatar
bump for serious offers. make one!
Old Aug 29, 2003 | 06:08 AM
civictypenos's Avatar
Default Re: (djmatix)
$110 shipped?serious as in $$ now
Old Sep 2, 2003 | 05:22 AM
djmatix's Avatar
SOLD!
NLR
Sep 9, 2006 06:31 AM
sPaRk'iT
Apr 26, 2004 05:46 PM
Tad
Dec 17, 2003 03:10 PM
