Very Quick question...how much MTF do I put in my tranny???
hey, going to replace my manual transmission fluid tommorow and was wondering how much do I need to put into my tranny??? as in liters???
I have a 1994 honda civic with D16Z6, 1.6L engine
With the car on level ground fill till it comes out at the fill/check plug on the side of the differential case. But i agree with the above 1.9-2.0 Quarts.
1.8 for refil 2 for rebuild.
open the filler hole behind the passenger side axle, put car on level ground.fill. when fluid comes out. its full.
im also changing mine today i have a 97 LS anyone know how much my car should take? i think its 3 or 3.5 but im not sure
A 97 Integra calls for:
2.2l (2.3.US qt, 1.9 lmp.qt) at oil change
2.3l (2.4.US qt, 2.0 lmp.qt) at overhaul
-Ace
-Ace
I'd buy 3 liters of the stuff. Forget about the exact amount and just fill it with the car leveled out until it starts overflowing out of the fill hole. Don't forget to use new crush washers for the drain and fill bolts. Drain should be the same as the motor oil change, and the fill hole uses a larger size.
aoe_virus
12
Jun 20, 2005 06:05 PM
lonefuzzy79
Apr 30, 2002 07:51 PM
