Where can I find only the lower part of the JDM 4-2-1 ITR Header?
Old Aug 28, 2003 | 11:33 AM
nolimits's Avatar
Default Where can I find only the lower part of the JDM 4-2-1 ITR Header?
My '96 B18C (JDM ITR) swap came with the 4-2 manifold, but the 2-1 downpipe with o2 sensor bung wasn't included. It's a worthless piece by itself, so I'd like to find the other half!! Thanks for any help!
Old Aug 28, 2003 | 01:40 PM
B16b2b's Avatar
Default Re: Where can I find only the lower part of the JDM 4-2-1 ITR Header? (nolimits)
i have one from a ctr. it should be the same or better, and it bolts to the top piece of the stock manifold, and has a factory 2.5" collector. let me know.
Old Aug 28, 2003 | 04:43 PM
nolimits's Avatar
Default Re: Where can I find only the lower part of the JDM 4-2-1 ITR Header? (B16b2b)
wouldn't the itr have to come down further to clear the oil pan? I don't really know, but I'd hate to get it and have it not fit! How much would you want?
Old Aug 29, 2003 | 05:59 AM
B16b2b's Avatar
hmmm, that i'm not sure of....BUT the ctr block is slightly taller than th at of a regular b16a, so i'm still not sure.....
Old Aug 29, 2003 | 06:19 AM
jdm4life's Avatar
Try your luck on e-bay. I've seen the entire JDM header 4-2-1 for pretty cheap. Guess cause most people want the 4-1. Good Luck on it.
Old Aug 29, 2003 | 08:14 AM
advanracing62's Avatar
Default Re: Where can I find only the lower part of the JDM 4-2-1 ITR Header? (jdm4life)
CTR block is a B18C block de-stroked, length is the same.
Old Aug 29, 2003 | 08:28 AM
B16b2b's Avatar
Default Re: Where can I find only the lower part of the JDM 4-2-1 ITR Header? (advanracing62)
right, so theoretically it would work, given the ctr block is the same casting as a b18c-r.
Old Aug 31, 2003 | 05:38 PM
B16b2b's Avatar
sent another pm....
Old Nov 24, 2003 | 01:13 PM
Spids5's Avatar
Don't judge or question
I can get one if your still interested
egotistic
May 2, 2009 09:25 AM
TypeR 599
Oct 6, 2005 03:20 PM
marc-111
Aug 15, 2005 08:01 AM
Speedz
Mar 31, 2003 05:20 AM
