HEat shields
Old Aug 16, 2001 | 08:25 AM
blythzithe II's Avatar
New User
Default HEat shields
a friend of mine recently got a b16a swapped into his crx si,problem is he also got a aftermarket exhaust also installed w/no heat shields,and now his car puts out tremendouse heat around the console about like riding on a oven and around the shifter,any help on what he might beable to do about the heat would be appreciated
Old Aug 16, 2001 | 11:30 AM
91ED7Si's Avatar
Default Re: HEat shields (blythzithe II)
well he needs to either take the exhaust off and wrap it in some thermo insulation and or put the heat shields back on.
Old Aug 16, 2001 | 11:35 AM
New User
Default Re: HEat shields (91ED7Si)
he has it wrapped right now in thermo wrap,still hotter than ever,and the original heat shileds are onthe original exhaust
Old Aug 16, 2001 | 11:52 AM
91ED7Si's Avatar
it sounds like the only option is to have new ones made.
Old Aug 16, 2001 | 12:04 PM
glagola1's Avatar
it sounds like the problem runs deeper than a heat sheild. I've got a turbo with no heatshields and my console does not get hot but my engine bay does.
I would check to see if the cat is working properly and is not clogged. When a cat is clogged or the motor runs mcuh too rich for a while the cat can get so hot it glows red.
Old Aug 16, 2001 | 12:52 PM
New User
Default Re: HEat shields (glagola1)
he has a hollowed out cat,but it is nt wrapped.maybe that would help,
Old Aug 16, 2001 | 01:46 PM
nawoj's Avatar
or just replace the cat
**** me off!
Old Aug 16, 2001 | 02:06 PM
New User
Default Re: HEat shields (nawoj)
what pissed you off
Old Aug 16, 2001 | 08:43 PM
crux131's Avatar
Not sure about the cause of the problem, but maybe adding some dynamat heat shield( made for the undersides of hoods ) to the underside of the transmission tunnel would help.
Old Aug 18, 2001 | 12:55 AM
brad.'s Avatar
Default Re: HEat shields (crux131)
ive never heard of that heat problem before
deving916
Jul 29, 2011 06:31 AM
bonstokLS
Jan 4, 2009 06:48 PM
IntegraLs94Cam
Oct 1, 2004 05:43 AM
yohan
Aug 31, 2004 12:43 PM
no2unenolife
Jun 9, 2003 03:32 AM
