injector resistor for sohc vtec engine question
Old Aug 27, 2003 | 02:38 PM
jdmkrazie's Avatar
Default injector resistor for sohc vtec engine question
i'm planning on doing a mini-me swap (d15b7 bottom d16z6 head) into my 88 dx hatch. the engine has obd-1 injectors i heard that they don't work with an injector resistor. do i still convert the dpfi to mpfi the same way i would for a zc swap or do i have to do something else? if i do have to do it another way what is it?
Old Aug 27, 2003 | 04:45 PM
MrTodd's Avatar
Default Re: injector resistor for sohc vtec engine question (jdmkrazie)
If you don't want an OBD-1 system, do the MPFI conversion the same way you would for a ZC (excluding the extra distributor wiring change). Only use OBD-1 injectors w/out the resistor.
repingjdm
10
Sep 28, 2010 04:37 AM
makoto
Apr 11, 2007 10:38 AM
nevin
Aug 16, 2005 03:21 PM
Crimson_Tide
Jun 30, 2005 12:31 PM
civicefdx
Oct 24, 2004 03:25 PM
