bah! damn you honda!!!
so my car is in the shop getting the cross weights set and an alignment done. anyone want to guess what little thing has been costing me $75 an hour since about 2 o'clock today??
nate
nate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">Skunk 2 upper A-arm camber adjustment?
My Skunk/2 alignment cost me $80 at Gran Trusimo in GA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x »</TD></TR><TR><TD CLASS="quote">so my car is in the shop getting the cross weights set and an alignment done. anyone want to guess what little thing has been costing me $75 an hour since about 2 o'clock today??
nate</TD></TR></TABLE>
Taking off the trunk and putting a hatch on the back?
todd's the winner!
200k+ miles and the accompanying rust seems to have welded the rear toe adjusters.
0wn3d by new england winters again
nate-hoping he'll have money left to pay for topeka
0wn3d by new england winters againnate-hoping he'll have money left to pay for topeka
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x »</TD></TR><TR><TD CLASS="quote">todd's the winner!
nate-hoping he'll have money left to pay for topeka</TD></TR></TABLE>
don't feel bad nate. my old coupe just barely had over 100k miles on it and the bolts for the toe adjusters were seized also, on both sides of course. They had to cut the compensator (toe adjusting) arms off with a torch, cut thru the thin sheet metal to get back there to pull the bolt out. It was a mess. So, I got new compensator arms (the cheapest part of the deal, like $30 a side). Make sure they use at least grade 9 bolts.
where did you take it to get weighed and aligned?
edit: I made sure I gooped up everything back there with a ton of anti-seize.
steve
0wn3d by new england winters againnate-hoping he'll have money left to pay for topeka</TD></TR></TABLE>
steve
Small Fortune Racing is doing the corner weight, swaybar preload, and alignment. we're also installing some pretty trick parts in the rear suspension.
nate
nate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpiceyRice »</TD></TR><TR><TD CLASS="quote">
Did Jeff (I think that's the alignment guy's name at GT) say anything good or bad about using these things (adjustable upper A-arms, right?) on your car. For some reason, he was very reluctant (not wanting to increase tire wear) to even add any front toe out for me when he found out I use the car for daily driving.
</TD></TR></TABLE>Did Jeff (I think that's the alignment guy's name at GT) say anything good or bad about using these things (adjustable upper A-arms, right?) on your car. For some reason, he was very reluctant (not wanting to increase tire wear) to even add any front toe out for me when he found out I use the car for daily driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Littleton »</TD></TR><TR><TD CLASS="quote">I'm looking for a traction control system for a honda. </TD></TR></TABLE>
Didn't you know that all Hondas come standard with a traction control system??
It's the button marked "A/C", right there on the dashboard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxQ »</TD></TR><TR><TD CLASS="quote">
Right on brother! I used to have this highly advanced and cool (literally) driver aid. But it has since been removed.
Anthony "Mario" Crea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRacer »</TD></TR><TR><TD CLASS="quote">$75 for my corner weighing and alignment
That's $75 one set price, not per hour
add $600 to that and that's what i just dropped for mine. of course, that includes some custom trickery in the rear suspension and working with those damn buggered up toe links but what can you do?
the front swaybar needed 3/8" of spacers to remove all it's preload, and there was 125lbs jacked across the chassis. the drive home revealed the car now turns the same if i go left or right. go figure.
the alignment isn't quite what i wanted, but i can tweak from the baseline i now have. i also finally have room for my rear tires.
nate
</TD></TR></TABLE>add $600 to that and that's what i just dropped for mine. of course, that includes some custom trickery in the rear suspension and working with those damn buggered up toe links but what can you do?
nate
CivicSiRacer
May 12, 2003 03:18 AM
