Can't keep car running!!! please help
Old Aug 27, 2003 | 11:28 AM
rig9896's Avatar
Default Can't keep car running!!! please help
95 civic ex coupe
with a 96 b16a2 motor completly rebuilt ( JE psitons and eagle rods, port flow head)
OBD 1 p28 computer remprogrammed by Katman
I have a b16a2 motor that i recenlty just put in. I'm 99% sure my timing belt was installed right. I checked my plugs and have the just bought the right fuel hose for the swap. My problem I think might be the distributor. My car won't stay started unless i hold the gas pedal at 3000 rpm then it runs smooth, but if I let off it dies out and stalls. It is also hard to start. Can this be caused by the distributor not being advanced or retarded right? Or am I dealing with something else?
Old Aug 27, 2003 | 12:07 PM
ATS_Antone's Avatar
Default Re: Can't keep car running!!! please help (rig9896)
hmmmmm, maybe you have a huge vacuum leak?
Old Aug 27, 2003 | 05:18 PM
Sunrise City Rider's Avatar
You may have sealed the IACV port on the TB or IM...Did you use any sealant? No need for that...Just the gasket is fine...
Zee
Old Aug 27, 2003 | 08:36 PM
blah13's Avatar
Default Re: Can't keep car running!!! please help (Sunrise City Rider)
Be sure your throttle cable is tight, too much slack can cause the engine to die when you let off. An easy check.
Old Aug 28, 2003 | 08:01 AM
rig9896's Avatar
Default Re: Can't keep car running!!! please help (blah13)
THanks for all the input I will check it out
Andycuso
Feb 12, 2013 08:52 AM
eg6king!!!
34
Feb 23, 2011 05:29 PM
sirt_eg
Apr 17, 2007 08:40 AM
SpoonyGSR
Apr 10, 2005 03:28 PM
