Oil overfill?
What happens if you use more oil than you are suppose to? On the dipstick, the maximum oil line is past the top. I used 5 quarts of Mobil1 FUll Synthetic 10W-30. Are there any effects?
high oil pressure is rough on your seals... Pretty much if you put too much oil in, the extra oil will find a way out... You may see some oil leaking out hear and there...
acura, crx, ek, fill, honda, hondatech, oil, overfill, overfilled, overfilling, overfillled, quarts, tl
