b16 block/ CTR pistons
Old Aug 15, 2001 | 08:38 PM
KayOs's Avatar
Default b16 block/ CTR pistons
I have a JDM b16 block (took head off, already) on a crate. How difficult is the process of installing CTR pistons myself? I am trying to save labor fees by taking out the pistons and having a machine shop install CTR pistons to my stock rods. I would do the rest.
Old Aug 15, 2001 | 09:31 PM
tysir's Avatar
New User
Default Re: b16 block/ CTR pistons (KayOs)
actuall i havent done this yet but im in the process of doing an lsvtec, so what i have research and told from people in honda tech is that when installing any pistons you have to hone the cylinders always when doing pistons. you might want you change your piston rings also, a must. with those mods there is must on honing the cylinders and new rings. cant reuse old rings and just put the ctr pistons. heard it will run fine for a while then blow on you.
Old Aug 16, 2001 | 03:58 AM
CRX_VTEC's Avatar
ts not that hard since you already have the motor out. I I had my pistons pressed by another shop cuz it was a pain in the a$$ otherwise I would have done it myself too.
Old Aug 16, 2001 | 06:45 AM
3rdShift.org's Avatar
New User
Default Re: b16 block/ CTR pistons (CRX_VTEC)
Pressing pistons onto rods is not something anyone here is going to do without a huge hydraulic press... as far as piston installation goes, get a HELM manual or other service guide that will walk you through the use of a ring compression tool to ensure smooth transition of the piston & rings into the block. Moroso has a nice tapered cylinder tool that allows easy compression of the rings as the piston is pressed into the cylinders. You should be able to pick it up from Summitracing.com and they shoul come in all of the standard sizes. (81mm, 81.5, etc.).
HTH
Old Aug 16, 2001 | 12:16 PM
KayOs's Avatar
I was not about to attempt putting the pistons on the stock rods. I was going to let a machine shop handle that aspect (taking pins out of pistons as well as assembling new CTR pistons).
Old Aug 16, 2001 | 10:25 PM
blkDOHCsol's Avatar
New User
you have to mill the stock rod to make the PCT(ctr piston) fit rite..good idea to get a helms manny..go to a good machine shop to get the rod modding done..you dont want them to mill too much...i think it is a pretty meticiulous thing..good luck with the install
Old Aug 17, 2001 | 11:22 PM
GZR4DR's Avatar
Default Re: b16 block/ CTR pistons (blkDOHCsol)
You only have to modify the rod if your using an LS rod. The B16A rod will hold the PCT piston just fine.
Also check all the bearings while your doing it. I however never recommend a novice mechanic to build the block. There are a lot of little steps not listed in the manual to getting it to run right. If done incorectly it will run, however the motor will smoke. My motto is get it done right the first time, or dont get it done at all. Dont be cheap.
[Modified by GZR4DR, 12:23 AM 8/18/2001]
jap305
Jan 3, 2012 03:33 PM
SoldMyEM1
Oct 13, 2004 07:45 AM
Touch
Apr 12, 2004 01:08 PM
95gsr
Jan 16, 2002 06:56 AM
