Horn not working and SRS light on?
Old Aug 27, 2003 | 05:02 AM
Grimm's Avatar
Default Horn not working and SRS light on?
My horn dosen't work and the SRS light is one. I think I need a new wire spool thing. It resides in the steering console, between the steering wheel and dash.
Does anyone know what it's called? I checked all other connections and ran the honda diagnostic. So I feel confident it's this wire harness thing that allows the steering wheel to be turned without the wires getting messed with. Where can I get one besides a honda dealer?
Old Aug 27, 2003 | 07:41 AM
salbaje's Avatar
Default Re: Horn not working and SRS light on? (Grimm)
yes check the reel and see if that is fugged up
Old Aug 27, 2003 | 07:54 AM
1bad-eg's Avatar
Yeah it sounds like the cablereel. Have you checked the srs code yet?
Old Aug 27, 2003 | 09:42 AM
Grimm's Avatar
Default Re: Horn not working and SRS light on? (1bad-eg)
Cable reel! thanks.... yea I need to investigate it more. Took it partly apart the other weekend but didn't get too far.
How much does that sort of thing cost? and is the work something I can do? (will my airbag go off or anything if I remove the steering wheel?)
SRS code? Well when I checked the ECU for codes nothing came up for the SRS as far as I know. Is there a different Diagnostic computer to use. I used an actual Honda diagnostic hand held thing.
Thanks again
Old Aug 27, 2003 | 02:03 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm &raquo;</TD></TR><TR><TD CLASS="quote">My horn dosen't work and the SRS light is one.
This may sound like an odd question. Do your brake lights work?
Old Aug 28, 2003 | 09:12 AM
Grimm's Avatar
Default Re: Horn not working and SRS light on? (Chiovnidca)
brake lights work as far as I know...
Old Aug 28, 2003 | 01:32 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm &raquo;</TD></TR><TR><TD CLASS="quote">brake lights work as far as I know...</TD></TR></TABLE>
That's not a very definite answer.
Old Aug 29, 2003 | 07:52 AM
1bad-eg's Avatar
Actually, if your car is a 96 or newer, you should be able to check the srs code with the Honda PGM Tester. If not, trip the light the old fashion way...jump wire.
shailoche
Jun 27, 2009 11:12 AM
erck
Jun 8, 2007 07:34 PM
EK4_JOSE
Mar 24, 2007 08:55 PM
GReddyB18C
Aug 17, 2002 01:06 PM
