vtec question
Old Aug 26, 2003 | 10:45 PM
DXDOHCVTEC's Avatar
Default vtec question
would it be ok to hook up a button or switch to the vtec solinoid instead of the computer telling it when. what are the negitive sides of doing this? at low, high rpms?
Old Aug 26, 2003 | 11:19 PM
totaled's Avatar
Default Re: vtec question (DXDOHCVTEC)
you could do this, but why go through the hassle?
At too low rpms it will make ur car run rich as hell and it wont give you any performance........at higher rpms thats usually where its set.....but why not get a VAFC Controller and just set it?
Old Aug 27, 2003 | 01:03 PM
eg6h8k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DXDOHCVTEC &raquo;</TD></TR><TR><TD CLASS="quote">would it be ok to hook up a button or switch to the vtec solinoid instead of the computer telling it when. what are the negitive sides of doing this? at low, high rpms?</TD></TR></TABLE>
u dont wan to use vtec like u would..say..NOS...just let the ecu do the job..plus when ur messing around on the street..its hard to activate the vtec at the right rpm..in short...DON'T DO IT!!
Old Aug 27, 2003 | 02:08 PM
Spade's Avatar
Default Re: vtec question (totaled)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totaled &raquo;</TD></TR><TR><TD CLASS="quote">you could do this, but why go through the hassle?
At too low rpms it will make ur car run rich as hell and it wont give you any performance........at higher rpms thats usually where its set.....but why not get a VAFC Controller and just set it?</TD></TR></TABLE>
Actually on a stock ECU, you'd really **** it off and make it go into limp mode.
The ECU won't switch fuel maps until the specified RPM anyway so you will be running leaner fuel mix.
THe VTEC lobes actually make less power than the normal lobes under 5000 rpm.
In short, let the ECU do it and just get larger cams.
Old Aug 27, 2003 | 02:35 PM
VTECorona's Avatar
Default Re: vtec question (Spade)
If it was worthwhile to do that, I think honda would have made it kick in at other times (which would be what you're trying to make it do). I would leave it as is until you get some cams then you can get a VAFC to adjust your vtec point to where it will get you more power (aftermarket cams make power at higher RPMs so up'ing the vtec point is worthwhile).
Old Aug 27, 2003 | 09:09 PM
DXDOHCVTEC's Avatar
well it was just a thought, but it would be on a mugen ecu, but if it is already gonna expect vtec to be activated and its not it would be a loss oh well. thanks for the feedback
Voodooboy520
Honda S2000
Sep 29, 2008 10:14 AM
da6jdmteg
Jan 18, 2006 08:25 AM
microsoft_sux
Aug 24, 2004 07:37 PM
Magick211
21
May 21, 2002 11:17 PM
CLICC916
Sep 20, 2001 11:06 PM
