Best engine oil for D15B2?
Old Aug 26, 2003 | 03:51 PM
youngwon22's Avatar
Default Best engine oil for D15B2?
I need to change my engine oil, and i was wondering if the engine oil is used as a tranny fluid too, and which engine oil would you choose for a CRX?
Old Aug 26, 2003 | 03:59 PM
Vinceg99's Avatar
Default Re: Best engine oil for D15B2? (youngwon22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngwon22 &raquo;</TD></TR><TR><TD CLASS="quote">I need to change my engine oil, and i was wondering if the engine oil is used as a tranny fluid too, and which engine oil would you choose for a CRX?</TD></TR></TABLE>
Well first off yes you CAN use rehular motor oil for the tranny. But there are better things out there like Honda MTF or GM Syncromesh. Those will be better for your tranny since they contain friction modifiers that your tranny needs plus better over all protection.
As for which motor oil this is a pointless thread first off do a search it has been beaten to death many many times before and plus your going to get so many different opinions on what to use. Some people like this and other like that. Find a good brand and try it out stay away from the cheap stuff and you will be fine.
*EDIT* OK even though plenty of people will disagree with me......Getting synthectic oil is pointless UNLESS it has been in there from basically the start you shouldnt break in a motor with synthetic since it is such a slippery oil but after the break in period you can use it with great results. But I can tell you this if you ahve a motor with say 100,xxx miles on it and it has been ran with regular oil its whole life and then you start using synthetic your not going to notice a difference except for maybe opil leaks that werent there before since its something the motor isnt used to running and when you have a older motor things tend to leak easier with the synthetic oil.
Old Aug 26, 2003 | 04:08 PM
.ShawnD.'s Avatar
Default Re: Best engine oil for D15B2? (Vinceg99)
i change oil alll day long .. i use to be a mobil 1 synthetic fan but im going to switch to valvalen synthetic it seems to come out cleaner in the long run
any of those 2 with a honda filter or Hemp filter
both 5w30
Old Aug 26, 2003 | 06:06 PM
youngwon22's Avatar
thanks for the replies, another thing, i never got to find out what engine oil my car is running on right now but i was planning to buy valvoline synthetic, would it be worse?
Old Aug 26, 2003 | 06:18 PM
Ef Whore's Avatar
Default Re: (youngwon22)
With an older engine just use Quaker State 5w-30.
Old Aug 26, 2003 | 07:20 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (Ef *****)
With an older engine you should use thicker oil
new cars use 5w20 if your compression isn't as good, go with 10w30 10w40 and so forth
with my old corolla that i had with 300k i used 20w50
you need it trust me depending on your motor
Old Aug 27, 2003 | 05:44 AM
1990hondaHF's Avatar
Default Re: (MugenHonda)
The older an engine gets, it requires higher viscosity oil engine. My Dad's Explorer is over 200k and if we use anything lower then 20w-50, he burns oil like crazy. 20w-50 does the trick. I guess it fills those gaps created by years of wear and tear....
Old Aug 27, 2003 | 07:54 AM
slooogsr's Avatar
ive been using a castrol sythetic blend 10w30 after the break in........... is this a bad thing?
Old Sep 1, 2003 | 09:23 PM
youngwon22's Avatar
When i just pour oil into an engine, does that go right into tranny too?
mattbatson
Honda Civic (2006 - 2015)
Jun 3, 2011 09:44 AM
DiMpL3s
54
Nov 29, 2007 07:52 AM
d3xt3r19
Oct 9, 2007 07:51 PM
kornerk12
Jan 6, 2006 09:10 AM
K-Spec
Sep 27, 2005 09:15 AM
