brake light on my crx wont go off
which light doesn't go off?? taillights or the icon on the gauge??
if it's the taillight, check the sensor that goes on top of your brake pedal, maybe there is the problem. the other day the same **** happened to me, and a good piece of paper fixed the problem!!!!!!
check it out!!!
check it out!!!
1 check to see if you have enough brake fluid.
2. check to see if the float is stuck on the brake fluid resovior
3 check to see if one of the bullet connectors came apart.
motormike40
Nov 22, 2006 09:41 PM
