Vtec went bad..
Old Aug 26, 2003 | 08:55 AM
Shorty C's Avatar
Default Vtec went bad..
so 3rd gear is pulling, when it hit around 6.7k rpm, its like vtec un-engaged and there was a loud hissing when vtec stopped pulling. The cel came on after and I have no clue whats going on.
the car is a 99 si with bolt ons
any help is appreciated.
Old Aug 26, 2003 | 09:29 AM
dkim48's Avatar
Default Re: Vtec went bad.. (sykol)
Maybe not enough oil= not enough oil pressure for the vtec solenoid? Try the tech forum. Maybe wiring too many things to consider. Good luck.
Old Aug 26, 2003 | 09:33 AM
advanracing62's Avatar
Default Re: Vtec went bad.. (dkim48)
how long have you had the car? what did you change lately? has this happened before? any previous cel issues?
Old Aug 26, 2003 | 09:42 AM
Shorty C's Avatar
Default Re: Vtec went bad.. (advanracing62)
had the car a little over 2 years. I have to admit that its been through hell and back. Misshifted a couple times, had valves adjusted before. Random CELs. But before this incident everything ran fine. My car does seem to bog throughout the power band. It does feel like bad air/fuel mixtures.
Old Aug 26, 2003 | 10:03 AM
Shorty C's Avatar
Update:
I just reset the ECU and the CEL went off. When I rev my car, it bogs down close to zero rpm(car feelin like its finna cut off) and jumps back up to normal idle at 900
Old Aug 26, 2003 | 10:53 AM
spun Vtec's Avatar
bummp im kinda haveing the same prob with my sohc vtec
Old Aug 26, 2003 | 10:56 AM
spun Vtec's Avatar
Default Re: Vtec went bad.. (spun Vtec)
what oil pressure has to be pressent for vtec to inguage?
Old Aug 26, 2003 | 01:58 PM
preluder's Avatar
i think its oil pressure from the oil pressure sending unit. or it could be how much oil you would have in the actual oil pan did you check to see how much oil you have had in there lately. Check your fluids oil and ignition components and be sure to pull codes even if they arent present.
Corksil
Dec 17, 2009 02:50 PM
stealthpenguin
Jun 6, 2007 11:40 PM
MOST
11
Feb 28, 2007 01:29 AM
shipsaeki
Jun 10, 2003 06:21 PM
shipsaeki
Jun 10, 2003 05:34 PM
