What to wire when installing a 94/95 GSR Swap into a 95 Civic Si?
Guys..
i got a 95 Honda Civic Si, and i wanna drop in a 94/95 GSR Swap, what in all do i need to do to the wiring? And what needs to be swaped over? I did search but came up with slim results.
Thanks for your help.
vnt
vnt
very easy.. only wire you need to run is a knock sensor wire and that isnt needed if you upgrade the IM before swapping the motor, if you do upgrade then you should also get a chipped ecu as well.. there is plenty of stuff online about doing this swap, 94-95 or 95-01 is alll the same.. just make sureyou get an OBD1 p72 ecu or get the stock p28 chippped if you get the manifold
i'm kinda confused what does knock sensor have anything to do with IM?
vnt
vnt
If you get a skunk2 intake manifold, that elimates the 2ndary butterfly wiring..So the only thing left to do is wiring the KS [knock sensor]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by navin »</TD></TR><TR><TD CLASS="quote">If you get a skunk2 intake manifold, that elimates the 2ndary butterfly wiring..So the only thing left to do is wiring the KS [knock sensor]</TD></TR></TABLE>
and if you have the skunk2 IM you SHOULD have a chipped ecu so you would not even need a knock sensor with some chipped ecu's
JDMb18c1HATCH
Jun 23, 2010 08:37 AM
NIGHTCRAWLER94
Apr 11, 2004 04:53 PM
