how the fUq do u get autometers air\fuel ratio gauge to work on my 02 ep3 ?
Old Aug 26, 2003 | 12:25 AM
civic_sivtec's Avatar
Default how the fUq do u get autometers air\fuel ratio gauge to work on my 02 ep3 ?
i got a 02 civic Si. i purchased an autometer air\fuel ratio gauge. i can get it to power on but i need to know how to get it to read my air\fuel ratio? where do i hook up the purple wire ? pls help me out... thanks....
Old Aug 26, 2003 | 04:27 AM
chunky's Avatar
usually it connects to the o2 sensor, primary.
Old Aug 26, 2003 | 07:18 AM
.RJ's Avatar
.RJ
Default Re: how the fUq do u get autometers air\fuel ratio gauge to work on my 02 ep3 ? (civic_sivtec)
The gauges arent worth much past a pretty light show anyways.
Old Aug 26, 2003 | 07:25 AM
eg_nezay's Avatar
Default Re: how the fUq do u get autometers air\fuel ratio gauge to work on my 02 ep3 ? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">The gauges arent worth much past a pretty light show anyways.</TD></TR></TABLE>
Yup, he is correct. They arent accurate at all, and could be dangerous when it comes to tunning.
Old Aug 26, 2003 | 09:42 AM
oldB18EF's Avatar
Default Re: how the fUq do u get autometers air\fuel ratio gauge to work on my 02 ep3 ? (eg_nezay)
send it to the primary o2 wire on the ecu
Old Aug 26, 2003 | 11:15 AM
chunky's Avatar
the gauges are fine.
but hooking up a gauge to a relguar o2 sensor is pretty worthless. hook it up to a wideband, and you're money.
Old Aug 26, 2003 | 02:39 PM
thanks for all the help on those who posted. the thing is i hook it up to the o2 sensor... (white wire)... the light goes crazy.... it swings in the orange range and one green line is also lit. this is when its at idle.... is this how its supposed to be ? thanks for the help.....
Old Aug 26, 2003 | 04:15 PM
Most-Wanted's Avatar
It will swing from lean to rich out of wide open throttle. put the gas pedal to the floor and it should stabilize in the green somewhere. White is correct on most others.
brad98prelude
Dec 28, 2005 04:17 PM
hondaguyexsi
Oct 8, 2005 06:58 PM
Johnny_Rocket
Mar 16, 2005 06:35 AM
WAX
Jan 5, 2005 03:55 PM
