b18b auto tranny any power difference?
Old Aug 25, 2003 | 10:18 PM
Soled Out's Avatar
Default b18b auto tranny any power difference?
I know that a b16a that came originally with an auto tranny is a little weaker then the ones that come with the 5spd, i think the cams are milder. So my question is, does a b18b integra with an automatic make less powerthen a b18b that came with a 5 spd tranny, or are they the same hp wise? Thanks
Old Aug 25, 2003 | 10:43 PM
Loveless's Avatar
Default Re: b18b auto tranny any power difference? (Gray EG)
I believe they're the same hp
Old Aug 26, 2003 | 12:58 AM
xteg95's Avatar
Default Re: b18b auto tranny any power difference? (Loveless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">I believe they're the same hp</TD></TR></TABLE>
same
are you sure on the b16a...never heard of them using differnt cams to accomidate the transmission...unless this is a Jap thing.
Old Aug 26, 2003 | 04:58 AM
Soled Out's Avatar
Default Re: b18b auto tranny any power difference? (xteg01)
I heard that they used weaker camswith the motors with auto trans, maybe its just a myth.
Old Aug 26, 2003 | 08:06 AM
WundedSaint's Avatar
it's a myth....same exact engine...just different ecu and fuel settings.
rmc
Old Aug 26, 2003 | 12:04 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: b18b auto tranny any power difference? (WundedSaint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WundedSaint &raquo;</TD></TR><TR><TD CLASS="quote">it's a myth....same exact engine...just different ecu and fuel settings.
rmc</TD></TR></TABLE>
Exactly. It's the same exact motor with a different ECU and some interior stuff (guage cluster, center console, etc). Also some wiring for the automatic transmission control box thing won't be there, obviously.
The automatic will make less power per se on a dyno just because you will have more friction loss through the automatic tranmission. Other than that, it's the same. The 5-speed will be faster because you can shift faster than the automatic can.
(Don't get all technical and say you can't shift faster than an automatic, because I know it's true, but it will engage gears faster with a manual transmission).
Old Aug 26, 2003 | 12:10 PM
Hites
Guest
Posts: n/a
Default Re: b18b auto tranny any power difference? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">(Don't get all technical and say you can't shift faster than an automatic, because I know it's true, but it will engage gears faster with a manual transmission). </TD></TR></TABLE>
you can, but the average joe shmoe would probably **** up his tranny trying some |V|4D $|-|][f+][|\| $|&lt;][LlZ y0! tried to make that as ricey as i could . i wouldnt be surprised if you didnt have a damn clue as to what it says.
Old Aug 26, 2003 | 12:12 PM
Hites
Guest
Posts: n/a
some guy in another thread said that theres a 20hp difference. sorry about not combinging posts; i hope you excuse my dumbassity.
Spins
Aug 14, 2004 03:30 PM
Phastnphun
Mar 25, 2003 04:51 PM
SPiFF
Dec 18, 2002 01:16 PM
