help tial 38 mm wastegate
Old Aug 25, 2003 | 04:50 PM
blackfrohatch's Avatar
Default help tial 38 mm wastegate
help my wastegate will open with 2-3psi i wasnt getting much boost in the car then i took it out and used this little air compressor i had and put 2-3psi in it and the valve was opening. when i got it i ordered the .4 bar spring and that is about 5.88 psi. whats wrong here....the vac line is connected after the bov on the charge pipe. it has been connected to the turbo to and dose the same thing. should i just get a boost controler or should i call them up and get the right spring.
thanks
justin
DelSolMarine
Apr 17, 2022 10:21 AM
flangemastermike
Jun 13, 2007 04:46 AM
w0ng_sta
Aug 29, 2006 07:31 AM
nyjdmhatch
Jun 10, 2005 03:54 PM
arsenaldragster
Jul 5, 2003 11:02 PM
