Hone before or after hot tank?
Old Aug 25, 2003 | 07:36 AM
Smoothy's Avatar
Default Hone before or after hot tank?
Which should be done first?
Old Aug 25, 2003 | 09:29 AM
gitwidit's Avatar
Default Re: Hone before or after hot tank? (Smoothy)
hot tank first, hone last is the way i've always done it. wonder if it really makes a difference?
Old Aug 25, 2003 | 10:24 AM
The Brown Kid's Avatar
Default Re: Hone before or after hot tank? (GITWIDIT)
sorry for ignorence but what happens when you HOT TANK?? i just did a search and it only brought up this one.
ok searched the archive.
"A true hot tank cannot be done to aluminum. a steam tank with degreaser is what most shops use nowadays. Most shops refer to a steam tank as a hot tank now."
Old Aug 25, 2003 | 10:40 AM
irev210's Avatar
Default Re: Hone before or after hot tank? (The Brown Kid)
you boil the block or "hot tank" b4 you hone
the reason being that machine shops dont work on greesy/dirty blocks
2nd reason why you would want to do a hot tank b4 a hone is because you want the hone process to remain greesed, or coated. They spray w/ WD-40 after they hone so it doesnt rust.
Old Aug 25, 2003 | 03:29 PM
AzG35's Avatar
Default Re: Hone before or after hot tank? (irev210)
Definately hone after hot tanking. The solvants in the "hot tank" can wash down the hone job if you do it afterwards. WD-40 is mild enough not to mess any of the crosshatch up.
mahatma
Nov 27, 2006 08:14 AM
LostAndFound
Welding / Fabrication
Oct 21, 2006 04:56 PM
null.
Jun 22, 2005 07:03 PM
STN_Pat
Oct 2, 2004 07:02 PM
SjCiViCHB
Feb 14, 2003 06:35 AM
