resurfacing rotor
Old Aug 15, 2001 | 09:22 AM
serious's Avatar
Default resurfacing rotor
i need to resurface my rotors, and helms says i need to use an on car lathe. to do that i'd need to take my car into the shop and let them do that, and i want to do it myself. would it still work if i took the rotors off and took them to my buddy's shop for resurfacing? or is there some reason why it needs to be done on the car?
Old Aug 15, 2001 | 09:30 AM
serious's Avatar
Default Re: resurfacing rotor (Teken)
do i just need to pull the rotor off, or do i need to pull the hub off as well? it's a prelude, if that makes any difference.
Old Aug 15, 2001 | 10:23 AM
3rdShift.org's Avatar
New User
When I bought my car, I found that the rotors had actually been "staked" onto the hub, which will most likely present a serious problem when I need to swap the rotors. If you car is new and hasn't been messed with, you shouldn't have too much of a problem.
Mr. Choi's Avatar
New User
No... You can have then resurfaced on or off the car... It is cheaper if it is off the vehicle do to the ease of (turning the said rotor)...
having a rotor resurfaced on the car??? how is that possible. resurfacing the rotor is usually done off the car by using a brake lathe. the only thing you can do to the rotor on the car is deglaze it with a sand paper, but resurfacing, i dont think so. explaing to me how you would resurface a rotor on the car, i have never heard this theory or tip. i think its impossible to get the rotor perfectly flat resurfacing on the car.
Old Aug 15, 2001 | 10:40 AM
serious's Avatar
staked? what does that mean?
Old Aug 15, 2001 | 10:44 AM
Mr. Choi's Avatar
New User
yes, i see now. never heard they can do that, i still prefer a brake lathe. easy and cheap to use. hey teken, do you think you can get a picture of that machine for me?
Old Aug 15, 2001 | 12:01 PM
serious's Avatar
Default Re: resurfacing rotor (Chois i-VTEC)
go here to check it out...
http://cgi.ebay.com/ebaymotors/aw-cg...271416&r=0&t=0
you can buy it to, if you want...
[Modified by serious, 1:03 PM 8/15/2001]
inaety
Suspension & Brakes
Dec 26, 2008 06:01 PM
PetroGuyX
Jun 26, 2003 02:10 PM
civic91
Apr 2, 2003 01:23 PM
misledyouth
Feb 27, 2003 12:39 PM
serious
Aug 15, 2001 12:56 PM
