d15 mini me fuel management, with conquest turbo????
i searched, but can not really find anything on mini me turbo set ups, im going to be runnining a conquest turbo at 5-7psi safely, and i was wondering what size injectors, and what fuel management should i use??
you should not need anything but a 8:1 fmu (raising rate fuel pressure regulator) and a adjsutable FPR set at 42-44 psi of fuel.
You will also need to use some checkvalves to keep the map from seeing boost. (can use a missing-link of you are usig a 93+d15 I believe).
On a d15 i do not recommend anything above 5-6lbs. Also you should consider a BOV s some sorts. Intercooler os not needed for that low of boosting.
Is it worth even doing the mini me and turboing?? or just turboing a d15?? would i see a major result with a mini me turboéd over just a plain d15 turboed?
miguelJ
Jan 26, 2017 05:01 AM
TurboSi
Mar 28, 2002 10:25 AM
DR. ON POINT
Jun 27, 2001 06:25 PM
