swap +save my A/C!
Old Aug 24, 2003 | 11:35 PM
HATCHMO92's Avatar
Default swap +save my A/C!
my girl drive's a 94 civic 4 door dx with a/c . we got a 2gen b-16 on the way from HMO . id like to save the A/C , so my idea is instead of undoing all the line's ill leave all of the asembely bolted to the mount , and just undo the 4 bolts that hold that mount to the block . then swing it foward and drop the new b-16 in and bolt it back on . with out removing any of the line's ? can this be done! and are the mounts for the b series really the same for the d series?(expect for the back one)
Old Aug 25, 2003 | 12:00 AM
tangb2023
Guest
Posts: n/a
Default Re: swap +save my A/C! (HATCHMO92)
just unbolt the 4 mounts.. and leave the compressor hanging to the side.. or use zip tie to hold it to the side.. the only way u can use the ac is to get a del sol a/c bracket.. like 120-30..@hondautomotiveparts.com.. search not sure if it right...
Old Aug 25, 2003 | 04:46 AM
Aceman64's Avatar
Default Re: swap +save my A/C! (tangb2023)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tangb2023 &raquo;</TD></TR><TR><TD CLASS="quote">just unbolt the 4 mounts.. and leave the compressor hanging to the side.. or use zip tie to hold it to the side.. the only way u can use the ac is to get a del sol a/c bracket.. like 120-30..@hondautomotiveparts.com.. search not sure if it right...</TD></TR></TABLE>
What he said, just did this last week.
-Ace
Old Aug 25, 2003 | 05:40 AM
Trey's Avatar
25 Year Member
Default Re: swap +save my A/C! (Aceman64)
The 99-00 P54 Si bracket will do the trick. I used it on my 96 CX swap and it was a direct bolt in using the Sanden compressor (CX OEM).
you can get it a lil cheaper from http://www.hparts.com
Old Aug 25, 2003 | 06:08 AM
Ivan's Avatar
senior gold member
Default Re: swap +save my A/C! (Trey)
aren't the 96 and up civic compressors different though? on my EK I used a crv ac mount with my stock compressor. but on an eg he should use the del sol dohc ac mount just to be on the safe side.
Mr EJ1 203
Apr 8, 2006 10:25 AM
rdawg000
Dec 6, 2004 05:26 PM
boomslang
Oct 27, 2003 04:49 PM
tbocrx
Sep 29, 2003 02:14 PM
