Does this increase horsepower and reduce engine bay heat?
Old Aug 24, 2003 | 05:17 PM
Hites
Guest
Posts: n/a
Default Does this increase horsepower and reduce engine bay heat?
having the vents on (no ac on) and having the slider all the way on hot? ive got a 95 teg.
Old Aug 24, 2003 | 05:41 PM
Nameless RB26's Avatar
Default Re: Does this increase horsepower and reduce engine bay heat? (Hites)
Yes, it does reduce heat. Not enough to benefit though.
No HP gains.
Old Aug 24, 2003 | 05:45 PM
chevyalltheway's Avatar
all it does is transfer heat to your heater core and therefore lowering your water temp just a little. not noticable unless you are almost overheating
Old Aug 24, 2003 | 09:56 PM
bushfreakz's Avatar
well.. i maxed out at 110 or something like that.. then i switched the temp gauge to the other side.. and it started pickup more speed..
YES it does make a difference...
Old Aug 24, 2003 | 10:56 PM
Starrman85's Avatar
Default Re: (bushfreakz)
i always leave it on vent if i dont have a/c on, but i dont put it on heat. i think the only time you'll notice a big difference is if your gonna overheat, then switch it to heat right away, and take that air out of the engine, and ur temp gauge will down..
heh, had first hand experiance with that just last week, good thing i knew what to do. cracked radiator, so was low on coolant, but all is good now with new radiator.
Old Aug 25, 2003 | 09:09 AM
Hites
Guest
Posts: n/a
Default Re: (STARRMAN85)
what if i had a jrsc?
eddie7978
Mar 22, 2018 08:33 AM
raider1qaz
Feb 17, 2013 01:52 PM
freefall365
Oct 24, 2010 11:30 AM
Silvteg95
Aug 7, 2005 07:00 PM
miksew
Jan 3, 2004 08:10 PM
