23mm rear swaybar questions??
i have a 99 civic si. decided to go from the stock 13mm rear swaybar to the bigger 23mm jdm rear swaybar. my questions is what d-brackets ans endlinks will work with this setup. i tried to get the jdm honda bushings from r&d but they said they were no longer available... Any help would be appreciated
I think you can get this kit and it will bolt right on:
http://www.beaksproducts.com/products.html
That's what I ordered anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20bastard »</TD></TR><TR><TD CLASS="quote">that kit os for the usdm 22mm rear bar. hes asking about the 23mm
i dunno, maybe try and squezze the 22s?
Oh yeah....my bad. I don't know if that kit would work then.
I would go with bastard on this. Try to squeeze that bar onto the beaks kit. Regardless your gonna need something to reinforce your subframe so it doesn't tear.
I have the 22mm sway bar with beaks kit on my 99 Si. It made a VERY noticealbe difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airbag Club »</TD></TR><TR><TD CLASS="quote">i think you can still use your factory SI endlinks, because doesn't the beaks kit still use the factory SI endlinks?</TD></TR></TABLE>
who mentioned endlinks?
who mentioned endlinks?</TD></TR></TABLE>
Apparently HE did...read, lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si1999 »</TD></TR><TR><TD CLASS="quote">
my questions is what d-brackets ans endlinks will work with this setup.</TD></TR></TABLE>
yep i metioned endlinks. i know tons of people have used this so they should know what endlinks and d-brackets will work... and thanks to those who have replied so far.
Your talking about a difference of 1mm. You can use the same bushings. My local autozone carries Energy Suspension 7/8" poly swaybar bushings w/D brackets. Thats what I used, and it fit perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilsel »</TD></TR><TR><TD CLASS="quote">Your talking about a difference of 1mm. You can use the same bushings. My local autozone carries Energy Suspension 7/8" poly swaybar bushings w/D brackets. Thats what I used, and it fit perfect.</TD></TR></TABLE> from the usdm itr to the jdm itr is a difference of 1mm. from the usdm si to the jdm itr is a difference of 10mm. thats y i am asking what things will work with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si1999 »</TD></TR><TR><TD CLASS="quote"> from the usdm itr to the jdm itr is a difference of 1mm. from the usdm si to the jdm itr is a difference of 10mm. thats y i am asking what things will work with it.</TD></TR></TABLE>
Oh, in that case you can use the same endlinks, but will need different bushings (22mm, 23mm or 7/8") should all work. Not sure about the D-Brackets. BTW I have a set of 22mm rubber bushings still in the packaging if you want to pay shipping they are yours.
Zulu888
Aug 17, 2006 07:43 AM
