Need help!!! car won't start in heat
Old Aug 23, 2003 | 10:03 PM
93egsi's Avatar
Default Need help!!! car won't start in heat
alright.....today when i got back from playing golf, i tried to start my car, and it wouldn't start......it was turning, but it wasn't starting. After about 3 or 4 times of turning the key, i pumped the gas one time and tried to start it again, and bam it started up but it started off idleing at like 3500. This is the second time this has happened, and both days that it happened it was hot as **** and very humid. I don't think it can be the battery or the starter, or can it be? Can anyone please help me with this problem....i don't know what to do.......thanks in adv.
Old Aug 24, 2003 | 12:26 AM
ill phil's Avatar
Default Re: Need help!!! car won't start in heat (93egsi)
No offense, but there have been a million threads about starting problems and them being heat related lately. Try searching first......
First- do all of your accesories (radio, lights, etc) work? When you turn the key to on position do you hear the fuel pump whine for 2-3 seconds and then the check engine light disappears? If no whine, you may want to look into a Main Fuel Relay, which has been discussed with its symptoms in several topics. If you do have fuel pressure try checking for spark to determine if its ignition related. Good luck, do some searching....
Old Aug 24, 2003 | 01:36 AM
LSpimpTEC's Avatar
yeah i had this problem about a month ago. i thought it was a kill switch that i put in but turns out it was a relay. heres the post https://honda-tech.com/zerothread?id=562470 hope this helps
Old Aug 24, 2003 | 09:15 AM
BANting's Avatar
Default Re: Need help!!! car won't start in heat (LSpimpTEC)
i had the same problem in the heat, i dont know whats wrong but for i had to change my main relay and new spark plugs
Old Aug 24, 2003 | 05:21 PM
ill phil's Avatar
Default Re: Need help!!! car won't start in heat (EG1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG1 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem in the heat, i dont know whats wrong but for i had to change my main relay and new spark plugs</TD></TR></TABLE>
Hondas main fuel relays have shitty solders on the ends of the relay.... they go bad with heat etc.... still don't understand what you just said though
Old Aug 24, 2003 | 06:14 PM
93egsi's Avatar
Default Re: Need help!!! car won't start in heat (ill phil)
alright......i checked.....the radio, lights and everything works.....when i turn the key i do hear the fuel pump and the check engine light disappears.....so what else could be the problem?
Old Aug 24, 2003 | 07:11 PM
FifthGearOnline's Avatar
vapor lock?
Old Aug 24, 2003 | 08:17 PM
93egsi's Avatar
Default Re: Need help!!! car won't start in heat (FifthGearOnline)
so no one else can help with this problem?
Old Aug 24, 2003 | 09:15 PM
ill phil's Avatar
If its starting fine now, you may not be able to determine the problem since it seems to be intermittent with the high heat. Wait until a day when it won't start, then listen for the relay and test for spark. You could also test for spark now and make sure you're ignition is functioning properly.
Old Aug 24, 2003 | 09:19 PM
CivicNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsi &raquo;</TD></TR><TR><TD CLASS="quote">alright......i checked.....the radio, lights and everything works.....when i turn the key i do hear the fuel pump and the check engine light disappears.....so what else could be the problem?</TD></TR></TABLE>
If you are sure that the main relay is working then you will have to move onto the ingnition. check for spark. check you plugs. pull off dist. cap and make sure there is no moisture.
Old Aug 25, 2003 | 02:52 AM
93egsi's Avatar
Default Re: Need help!!! car won't start in heat (CivicNA)
thanks guys
Old Aug 25, 2003 | 11:21 AM
Daniel_san's Avatar
same happens to me, but it takes me a good 20-40 minutes to get it started again.
I just don't park in the sun anymore. cause my HB is a POS
Old Aug 25, 2003 | 11:28 AM
ryecatcher's Avatar
Default main Relay
Switch out or fix main relay, which is most likely the source of the problem. If you don't want to do that, next time it happens to you, bang on the lower part of the dash where the fuses are. This usually does the trick (no kidding).
Ryecatcher
If it doesn't work, hit it harder.
Old Aug 25, 2003 | 12:05 PM
ill phil's Avatar
Default Re: main Relay (ryecatcher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryecatcher &raquo;</TD></TR><TR><TD CLASS="quote">Switch out or fix main relay, which is most likely the source of the problem. If you don't want to do that, next time it happens to you, bang on the lower part of the dash where the fuses are. This usually does the trick (no kidding).
Ryecatcher
If it doesn't work, hit it harder. </TD></TR></TABLE>
Sounds funny but does work. It was suggested to me by some Honda Mechanic friend if I didn't feel like switching it out.
Old Aug 25, 2003 | 12:18 PM
92SiHatchie's Avatar
Default Re: main Relay (ill phil)
can it be the alternator as well?
Old Aug 25, 2003 | 02:38 PM
BANting's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill phil &raquo;</TD></TR><TR><TD CLASS="quote">
Hondas main fuel relays have shitty solders on the ends of the relay.... they go bad with heat etc.... still don't understand what you just said though </TD></TR></TABLE>
yea i just read what i posted and i don't even understand it
Old Aug 25, 2003 | 03:02 PM
93egsi's Avatar
alright......but i tried it today, i parked in the sun and it was hot as hell today, and it started right up.....but sometimes it doesn't. would it still be the fuel relay??
Old Aug 25, 2003 | 03:50 PM
redwinqs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsi &raquo;</TD></TR><TR><TD CLASS="quote">alright......but i tried it today, i parked in the sun and it was hot as hell today, and it started right up.....but sometimes it doesn't. would it still be the fuel relay?? </TD></TR></TABLE>
my car does the exact same thing...i just wait a few minutes and it starts up fine..o well
Old Aug 25, 2003 | 06:41 PM
hondasleeper's Avatar
Default Re: Need help!!! car won't start in heat (redwinqs)
From the symptoms you are describing, I would tend to agree with some of the other guys who had already mentioned it, it IS your main relay.
When the car doesn't want to start, listen for the fuel pump to prime, if it doesn't then it is your main relay. The problem, I'm sure is only intermitent, so keep a close ear/eye on the problem.
Old Aug 25, 2003 | 09:31 PM
CivicNA's Avatar
yes it can me intermitant and if it is the main relay then its only gunna get worse... just so you know.
Old Aug 26, 2003 | 02:54 AM
93egsi's Avatar
alright....thanks guys.....is it hard to replace the main realy?
Integra4lyfe069
15
Mar 10, 2009 02:51 PM
IntegraPir4te
Mar 19, 2007 10:51 AM
importnoodles
Sep 28, 2006 12:22 PM
civic efb16
Aug 8, 2005 09:00 PM
TurboedGSR
Sep 18, 2002 05:23 PM
