D16y8 into 98 dx hatch
Old Aug 23, 2003 | 08:57 PM
hahagasdcrx's Avatar
Default D16y8 into 98 dx hatch
I was just curious to what is involved with this swap?
I have a 97 D16y8 motor, engine, tranny and ECU from a buddy i did a gsr swap for and was wondering what if anything else is needed to swap the EX motor into my 1998 dx hatchback?
Also i have the complete engine to ecu harness for the EX....
as far as i know it is all swap in plug and play (drive) and just really wondering if it is really worth the swap??? because the dx is SOOOO slow compared to my Crx.
Crx has ls/vtec swap and drive the civic dx to work and back and to carry child around and just want a little more umph till my gsr buildup is done for it.....
thanks guys
Modified by 90crxzcgasd at 6:24 AM 8/24/2003
Old Aug 23, 2003 | 09:38 PM
blackhatchy's Avatar
Default Re: D16y8 into 98 dx hatch (90crxzcgasd)
ummm i think that the cat is different on the y8 than the y7, so there may be some clearance issues.
Old Aug 24, 2003 | 01:31 PM
civic-4-ges's Avatar
Default Re: D16y8 into 98 dx hatch (blackhatchy)
The cat's are different, Y7 is in the front of the engine, Y8 is under the car. Also a different header. The second O2 sensor is also under the car, which means you need to get the correct under dash harness to run it correctly. Contact Importautosalvage.com and they can get it for you. Got mine for 100$ Ask for Larry.
Old Aug 24, 2003 | 04:34 PM
Default Re: D16y8 into 98 dx hatch (civic-4-ges)
I have the y8 exhaust manifold with a high flow aftermarket cat along with new cat back exhaust system. So i think its pretty mush plug and play i hope
Old Aug 24, 2003 | 04:44 PM
The secondary o2 sensor will be your only problem. The EX engine harness does not have a place for it. You could however tap into the lines coming from the ecu and just connect it from there. Just a thought
uncle's Avatar
Just buy a hi flo y8 cat or stock and yer good to go.
Lasty K
27
Nov 1, 2017 09:03 AM
jald3rd
Oct 2, 2016 01:05 AM
LemonsEH2
15
Nov 5, 2008 03:44 PM
Dballa102587
Jun 20, 2008 07:06 AM
Ransom
Aug 29, 2002 07:11 PM
