Is bad to run in open loop all the time?
Old Aug 23, 2003 | 03:39 PM
TurboB18C1's Avatar
Default Is bad to run in open loop all the time?
I just got a hondata set up and trying to start my car, but when i do, it starts better in open loop then it does in closed loop? But the car runs very rich in open loop and back fires every couple of minutes but it runs smoothly but when its in closed loop it hesitates and jerks when i give it part throttle
::setup::
s200 p28
720cc injectors
FP-52 psi
Old Aug 23, 2003 | 08:23 PM
TurboB18C1's Avatar
Default Re: Is bad to run in open loop all the time? (TurboB18C1)
anybody
Old Aug 23, 2003 | 09:07 PM
notstock93's Avatar
just sounds like you need more tuning in your closed loop setup. I beleive youll be fine, as far as I know, closed loop is for saving gas anyway. correct me if im wrong.
Old Sep 8, 2003 | 05:40 PM
THE GAME IS THICK's Avatar
Default Re: Is bad to run in open loop all the time? (notstock93)
up
Old Sep 8, 2003 | 06:03 PM
Eyewitness's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">I just got a hondata set up and trying to start my car, but when i do, it starts better in open loop then it does in closed loop? But the car runs very rich in open loop and back fires every couple of minutes but it runs smoothly but when its in closed loop it hesitates and jerks when i give it part throttle
::setup::
s200 p28
720cc injectors
FP-52 psi </TD></TR></TABLE>
When it is open loop you will get horrible gas milage because it does not use feedback to control fuel delivery hence you run really rich...i have a mugen prog that runs in open loop all the time and my gas milage sux. So i would say that you have some tuning issues...or possibly one of your sensors is malfunctioning...its not necessarily bad but your gas milage will be
J . K .
Engine Management and Tuning
Aug 31, 2010 08:57 AM
SovXietday
Feb 27, 2007 03:49 PM
maxxd97
Jan 26, 2004 11:07 AM
hybridEj6
23
May 31, 2003 07:16 PM
