More realiable Fully built H22 or H23VTEC?
I was wondering what would be the best way to go for a daily driver? A fully built H22 or H23vtec? right now I have a jdm block with a fully built head so I'm in the process of working on the block. I was thinking of swapping out the jdm block and get another h23 and work on that but wasn't sure which setup would be more realiable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machinehead »</TD></TR><TR><TD CLASS="quote">h23 and h22 use the same block, so you'd only have to swap internals.</TD></TR></TABLE>
You also have to tap the deck and deal with the oil squirters.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laughinxxx »</TD></TR><TR><TD CLASS="quote">
You also have to tap the deck and deal with the oil squirters. </TD></TR></TABLE>
what do you mean you have to tap the deck?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laughinxxx »</TD></TR><TR><TD CLASS="quote">Satan do you have a pic of which hole needs to be drilled out for the VTEC conversion? </TD></TR></TABLE>
What I'm saying is that there is no hole to drill out. there is a plug in the oil orifice that you just have to unplug to route oil to the head. I don't have a good pic of where that is...as far as I know it's part of the girdle?
if it's the brassy-lookin plug I remember seein the last time I messed w/ my motor, it's in the block right near where the knock sensor plugs in....unless i'm wrong; i'll get some pics up later to show
acaccord04
Apr 14, 2004 06:55 PM
