can you make 400hp with a s-afc?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fsp31 »</TD></TR><TR><TD CLASS="quote">no.</TD></TR></TABLE>
No, because you won't be able to run 15 psi of boost without throwing a code. Using the hack is just a way to manipulate the voltage going to the stock map sensor and usually after about 9-11 psi (depending on the car - 9.25 on my crx si and it's around 10.65 on later model cars) it will start to throw a code.
I made 440whp using a safc, fmu, check valve, 440cc injectors and a 255lph pump. Yes you can make the power. You just need a little more than a safc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoEXturbo »</TD></TR><TR><TD CLASS="quote">I made 440whp using a safc, fmu, check valve, 440cc injectors and a 255lph pump. Yes you can make the power. You just need a little more than a safc.</TD></TR></TABLE>
the hack sucks and is totally different than what autoexturbo used. his set up has been run very successfully on probably over 1000 cars in the last 4 years.
but theres no need for all of that now that theres hondata and a variety of other complete standalones and tons of knowledgable tuners all over n. america. i used to run that set up and it worked great, but for the same money, you can use a better form of management.
completely agree with Karl. I don't know why I didn't mention running hondata or other standalone units. I now run hondata and it works like a charm.
From what I remember the 550's were harder to idle with the safc/fmu setup, but you can run big *** injectors with a standalone. The 550's will handle the 400whp though.
this question shouldnt be asked and why would you want to go cheap you spend all that money and try tp do the most important part the cheap way my answer is NO and plus your a/f ratio will be terrible even if you were tuning it with a wide band good luck with that ****
