Dynamat
Old Aug 22, 2003 | 09:00 PM
Sticky Tires's Avatar
* B A N N E D *
Default Dynamat
i have it on my stock trunk. is it reusable? i want to put it inside my rear bumper. is it possible to remove it and reuse it?
Old Aug 22, 2003 | 09:23 PM
rjr162's Avatar
Default Re: Dynamat (Sticky Tires)
you might have to get some of that spray tack or some other decent adheasive.... the glue tends to stay behind when you pull it off. You could try warming it with a hair dryer just a little to see if it will help pull the glue off.
Old Aug 23, 2003 | 11:44 AM
* B A N N E D *
Default Re: Dynamat (rjr162)
spray tack? where can i get that? good lookin` out rj
Old Aug 23, 2003 | 12:57 PM
SpeedDreamz.com's Avatar
SPray adhesive, any parts store.
Old Aug 23, 2003 | 02:27 PM
* B A N N E D *
Default Re: Dynamat (30psiCiv)
thanks
Old Aug 23, 2003 | 06:49 PM
rcurley55's Avatar
New User
By the time you peel it of, then try to reapply it with spray adhesive, you could just go to home depot, get some peel n seal and have both areas done.
It's not worth trying to uninstall that product IMO.
Old Aug 23, 2003 | 08:59 PM
* B A N N E D *
Default Re: Dynamat (rcurley55)
yeah thats what i figured. it's too sticky, I'll just buy something cheaper on line. thanks anyways fellas.
Old Aug 24, 2003 | 06:36 AM
LANDYcolorLAB's Avatar
For you bumper I would use a Spray rubberized undercoating. My personal favs are Transtar Rubberized Undercoating or Dynatron Rubberized undercoating. Inside a bumper cover you would probably get more life out of these then the dynamat. Plus if you give it some time between coats you can put it on thick. LAter
Old Aug 24, 2003 | 12:16 PM
* B A N N E D *
Default Re: (LANDYcolorLAB)
where can i get this rubberized undercoating?
Old Aug 24, 2003 | 04:48 PM
Default Re: (Sticky Tires)
NAPA. Autozone.
Old Aug 24, 2003 | 04:56 PM
* B A N N E D *
Default Re: (30psiCiv)
Old Aug 24, 2003 | 05:50 PM
rjr162's Avatar
actually you might want to hit up lowes also. I know they atleast use to carry a spray "foam" that would actually expand. It works great to silence areas where Dynamat won't go
Old Aug 24, 2003 | 06:51 PM
* B A N N E D *
Default Re: (rjr162)
we don't have lowes around here, just home depot. i went there once and asked about sound deadening material and some old guy said they don't have it.
Old Aug 26, 2003 | 02:40 PM
PupaScoopa's Avatar
So what's the idea of deadening the bumper anyway?
FTNW
Paint and Body
May 24, 2011 07:15 PM
Dredakid05
Feb 3, 2008 12:50 PM
dingobat
Paint and Body
May 17, 2007 09:15 AM
Xymox007
Jul 22, 2004 03:01 PM
Xymox007
Jul 22, 2004 06:03 AM
