cartech FMU question
The top **** adjusts the fuel pressure at 0psi so you can tune for a smoother transition into boost. The side **** is what adjusts the fuel to air ratio (the disc ratio). I don't know how to tell you to adjust it to the right ratio other than to take it to the dyno and play with it until you get a good fuel to air ratio. You turn it clockwise to raise the ratio higher, and loosen it (counter clockwise) to lessen the ratio.
SMOOTH97LUDE
Sep 20, 2003 05:27 PM
RNPoo7
May 7, 2003 03:24 PM
BoostedD15B7
Apr 22, 2003 05:55 AM
