B series tranny cases the same?
Old Aug 22, 2003 | 01:56 PM
hb_racer's Avatar
Default B series tranny cases the same?
My tranny broke where it connects to the motor mount. Both holes broke. So now i need a tranny casing. I have a GSR tranny on there. Would any casing work? Or do the casings have to be Hydro??? Any help would be great!
Thanks
Old Aug 26, 2003 | 06:11 PM
hb_racer's Avatar
Default Re: B series tranny cases the same? (hb_racer)
bump
Old Aug 27, 2003 | 12:51 AM
nominous's Avatar
wouldnt know about the GSR but from experience with EDM and JDM B16A cable gearboxes, they are different internally.
Can you not tap in a bigger hole and use larger bolts, or is the casing split ?
Old Aug 27, 2003 | 07:03 PM
hb_racer's Avatar
Default Re: (nominous)
The casing split. Also I have the b16 sirII which came as a hydro tranny. So anyone??? Are the cases the same?
thx
Old Aug 27, 2003 | 07:30 PM
mmuller's Avatar
Mad Scientist
Default Re: (hb_racer)
yes, you can swap it with the sir2 one.Remember to check clearances though
Old Aug 27, 2003 | 10:03 PM
hb_racer's Avatar
Default Re: (mmuller)
thanks!
Old Aug 27, 2003 | 10:50 PM
slrh22hatch's Avatar
they are all the same
crxsi361
Dec 22, 2009 11:19 AM
numberone
Jul 8, 2009 10:08 PM
SETxTHExSTAGExEJ1
May 30, 2007 05:47 AM
kyden
Aug 1, 2006 08:40 PM
