possible leaky headgasket
Old Aug 22, 2003 | 12:28 PM
jseames's Avatar
Default possible leaky headgasket
Here is the problem. My car starts to overheat at idle. It only does it while it's at an idle. I did a search on the problem and the only thing it looks like could be the problem is a leaky headgasket but I want to be sure before I go replacing it. I checked the radiator hoses and both hoses are hot, The fan comes on when it is supposed to, and there are no leaks in the radiator itself. In fact there are absolutely no visible leaks anywhere. However I am somehow loosing coolant in the overflow tank and have to keep refilling it after driving. I don't know where it is going. If there is anything else that it could be I would appreciate the feedback.
Old Aug 22, 2003 | 12:38 PM
Need4Boost's Avatar
Default Re: possible leaky headgasket (jseames)
yep...headgasket needs replacing....good luck
gvinson89
Jun 24, 2012 07:03 PM
mikeSONICGSR
Oct 11, 2009 06:07 PM
TrevorHiroshima
Jul 24, 2003 10:24 PM
intekragsr
Apr 29, 2003 01:46 PM
intekragsr
Mar 27, 2003 11:23 AM
