Skunk2 Intake Manifold
The skunk2 intake manifold is connected to the head and the throttle body is also connected to the skunk2 IM. Now I cant remember where all the hoses go. This is on my friends 98 GSR. The ones coming from the throttle body, well one goes to the Idle air control valve and the other one goes to the valve cover and intake tube thingy.
Where does the hose from the evap canister or the charcoal canister go?
And the coolant thing coming off the main coolant pipe on the intake manifold goes where? What is suppose to go on the back of the intake manifold?
Thanks for your info. They will be greatly appreciated. Thanks
You have to use a T to tap the Evap line into the thick tube going into the front of the manifold, I just used a longer tube and routed the Evap line out of the engine bay so none of the fumes would enter the engine bay area.
You have to block the extra coolant spout on the manifold, what I did was use an extra tube I had, a screw, a clamp, and JB weld and blocked it off.
The TB hose is a coolant hoose, just find the only open place to plug in a coolant hose
yea, but i remember there is another place you have to block off if you don't block off the extra spout coming from te manifold. I'm trying to remember the install, and I believe I attached the hose coming out of the TB to the block instead of using the coolant spout on te manifold.
jkalex05
Aug 23, 2009 06:01 PM
Bunga024
Mar 25, 2007 12:08 PM
GapxGuy
Mar 28, 2004 04:04 AM
obd2gsr
Oct 23, 2003 10:19 AM
